Syncing criteria
    Syncing criteria
    What criteria does TuneFUSION use when determining whether a file needs to be synced or not?
    • 46217
    Re: Syncing criteria
    Last modified, or you can enable the filesize check.
      So, any tag editing with preserve date/time enabled and, with padding, TuneFUSION won't sync these files?
        • 46217
        No, there is no way without reading each file fully to know there have been changes.
          Thanks for the confirmation.
