Galaxy S9 Not Recognised In Removable Drive List
  • yecnad
    • 9
    My GalaxyS9 is recognised in Windows10 as a mobile device and I can perform file operations between it and other drives. However it does not appear in the Tunefusion list as all the other drives do. I have noticed that having been recognised as a mobile device in Win 10 no drive letters have been assigned to the S9. I have tried using "diskpart" commands and turning on automount but neither have had the desired effect nor has enabling usb debug mode in Android. Will Tunefusion only recognise disks that have been assigned a drive letter? is there a workaround?
    EDIT- Think I need to use Foobar200 to add a mobile device to sysnc with Tunefusion so installed it. Foobar2000 sees the S9 but wont add any folder to the music libraries in the configuration box so still stuck.
    • 1932
    Re: Galaxy S9 Not Recognised In Removable Drive List
    AFAIK the S9 like other mobile phones and mp3 player nowadays supports only MTP (media transfer protocol). That way the device is not a storage device which you can assign a drive letter to. You can copy, paste and delete files with the file explorer, because windows translates the file operations, but you can't address the device i.e. with file operations in a batch job or robocopy.
    • yecnad
      • 9
      Thanks for the response, so must I conclude that Tunefusion will not sync with android devices using Win10?
        • 1932
        I can't answer this question, because I'm not a TuneFusion user.
          • 1932
          Have a look here:
          It should work with foobar2000.
            We do not use a drive, rather our own communication, if TF cannot see the device (it does not need to be connected to the computer, just wifi) then look at your firewall which might be blocking TF.
            • yecnad
              • 9
              All fixed thanks, was being a bit thick and not installed the mobile app!! Looking forward to trying it out.
