Getting 'sync finished with errors' after every sync
  • $E4V6vEg
    • Apr 2026
    I'm syncing flac files to foobar2000 on an iphone. After every sync, INVARIABLY, it says 'sync finished with errors' on my iphone. I can't find a tunefusion log. I checked APPDATA, Program Files etc. The files are synced properly. Everything is organized in directories. I'm obsessive about file names and ID tags. I use CDRipper. I'm using/syncing only one directory on my Windows PC for this purpose. The songs play OK.
    So what ERRORS does this mean ???
    • 46224
    %appdata%\TuneFUSION
    there will be a folder call Logs
    • $E4V6vEg
      • Apr 2026
      OK found it. Two corrupted files deleted, errors gone. TuneFusion
