macos Encoding settings don't persist as expected
  • whirrend
    • Dec 2024
    When I modify the encoding details, for example changing LAME mp3 to VBR or toggle any of the Advanced settings under encoding they don't persist after closing the Sync Settings dialog. Changing the type of encoding, Ogg Vorbis for example, does persist. However, again the finer details (quality) don't. Strangely going from LAME->Ogg Vorbis->LAME does end up changing the details for LAME, with no path back to the original configuration. Other settings, like processing or source filtering work as expected.
    My configuration is creating a sync to a new local directory sourced from my local music library.
    TUNEFusion Release 2024-06-28
    macos: Sequoia 15.1.1
    • 1650
    Thanks for the bug report.
    A problem causing TuneFUSION to ignore encoding settings changes when running on new Mac OS version has been fixed in a new beta build-
    • microflora
      • Feb 2025
      This beta build fixed this issue for me, thanks!
