How does ReplayGain work? Is there a (small) manual?
  • beijder
    • Aug 2024
    Hello,
    After purchasing PerfecTunes I noticed it also has a Replay Gain function.
    How do you manage this? Is there a (small) manual with all steps to be taken?
    When I select the "Help" function it is redirected to https://www.dbpoweramp.com/Help/Perf...replaygain.htm but that page is "dead"...
    What does "iTunes gain only" means and how to "Fix" this for multiple files.
    I can't select multiple files or Ctrl-A does not work. Do I have to do this per entry?
    What does "Scan all" do? Does it collect or set the gain levels?
    Guido
    • 46061
    Web page is now active
    • beijder
      • Aug 2024
      Spoon:
      Thanks for the correction of the link.
      After playing with the settings I managed to get it configured correctly and all my Apple Music songs correctly re-gained and play ok now!
      Guido
