Auxillary Input Problem
  • BenGundlach
    • Dec 2005
    Okay i am having a problem with auxiallry input. I'm trying to record my napster songs to mp3. I followed the instructions provided in another part of the forum, and I tired to follow them to the best of my understanding. Here is what my options configuration looks like.
    Now, i go into napster, find a song, any song because i am just testing this out right now. I play it, it plays fine, i stop it so it will start at the begining. I got back to the auxiallry input program, hit the record button and quickly jump back to napster to play the song. Here is what happens after about 5 seconds.
    It recognizes that something is playing and seems to record it. Also, i tok this screenshot at a VERY rare point when the VU bar was low green, it is usually spiking in the red, and my volume settings as seen in my other screenshot are almost muted. Okay, after it starts to record i hear the song play wierd, it echo's and sounds like it is double playing the song. i let it go on for about 20 seconds to just get a 30 or 40 second download to listen to. I go find the file on my harddrive, its there. I play it with windows media player, it plays, but again i hear the echo and the double play. I don't know how else to describe it, i can send you [anybody that is willing to help me] so you can listen to it. I am new to this program so it may just get a Operator [ME] Mistake, i hope thats all and someone can quickly help me.
    Also, sorry for some of my run on rentences and bad spelling/grammer. i had a longer, more though out better spelled post written before, but i was not logged on so i lost that post.
  • Razgo
    • 2532
    Re: Auxillary Input Problem
    turn your stereo mix down furhter. i have mine right on the bottom. it shoudlnt go into the red.
    • Craze
      • Oct 2002
      • 308
      Sounds like you're in a feedback loop.
      What are your settings on your Master Volume Control for the Master and Wave sliders?
      Seems like the Wave slider can contribute to the overall volume that is controlled by the Stereo Mix slider on your Recording Console. Seeing that your Stereo Mix slider is barely off of the bottom.
      You might try backing the Wave slider down and see if that helps any.
      Best Wishes,
      Craze
      • Razgo
        • 2532
        i didnt see a wav slider in that pic? but yes wav slider would have a significant effect.
          I think you enabled a setting in the PowerPack (the rocket) to Output Recorded Audio. Uncheck that.
          • BenGundlach
            • Dec 2005
            Umm, yeah that was checked but i never went into that.... hrrm il try it out.
