problem...!
  • niajef
    • Dec 2005
    problem...!
    im trying to convert .mov, and since it doesnt recognize the file when i opened dmc, i converted it to .m3u, using real player...now it recognizes the file, i opened it wit dmc, and a pop up says, support for .mov may be found at codec central, etc. and plz save it to the same folder...well the problem is that i cant find .mov at codec central among all those other formats...so...can any1 help?
    Re: problem...!
    .m3u is just a meta-file, or a pointer to the real file. Is this .mov file a video file or an audio file? What program created it?
      Re: problem...!
      .mov is a Quicktime format.
      It should be a video.
      You probably cannot convert it using dMC.
      You may have to play it in Quicktime (or any player that can play it) and use dMC Auxiliary Input to record the audio as it's played through your sound card.
      • gameplaya15143
        • Sep 2005
        • 276
        Re: problem...!
        if you have quicktime alternative installed, you can use the directshow input plugin to convert it
