Auxilliary Input Problem
  • cyberpro60
    • Aug 2005
    I am having great difficulty getting Auxilliary Input to work as I want.
    If I use an "external" sound source [connected to my sound card via line in] then I can record wave/mp3 files just fine using Auxilliary Input. If I try and capture anything "internal" ie something that's playing thru my sound card (like winamp music radio/cds/msn radio etc) I have no success at all.
    I have tried all the standard options to no avail. eg. I tried all of the possible "record" options including "line in", "stereo mix" and "Aux". Aux produces silence. Stereo mix produces awesome looping feedback which very nearly blew the house down (literally) but it proved impossible to get a decent signal that I can use from any of these options. I am at a loss for what to try next. Any suggestions?
    In case you wanna know. I am running XP Pro on a MSI K8 series motherboard using the built in ac sound card/audio system.
    Re: Auxilliary Input Problem
    For recording audio from your PC, the input should be Stereo Mix, with the volume slider 2/3 of the way up. Check the Powerpack options in dMC Auxiliary Input (click the rocket over on the right side) and disable Output Recorded Audio.
    • neilthecellist
      • Dec 2004
      • 1288
      Out of curiosity, is it always 2/3 of the way?
        No, it may have to be less. But certainly no more. :D
        • neilthecellist
          • Dec 2004
          • 1288
          Ok, I'll keep that in mind for the future.
          • cyberpro60
            • Aug 2005
            Thank you Christina, your solution was absolutely spot on.
            The destructive reverb/echo vanished and now I can make fantastic recordings of whatever is playing through my soundcard - awesome!
            You deserve to be elevated to the peerage
