Having 'Tag' problems, please help
  • ybw89
    • Apr 2005
    Well i am currently converting OGG to mp3.
    and after a conversion some files get cut tag's
    EG. 112 - Closing da club (Feat. Three 6 Mafia)
    TURNS OUT TO BE:
    is there sumthing i cood do about dis?
    Re: Having 'Tag' problems, please help
    What setting do you have for MP3 tags? Where are you reading the cut-off tags?
    Check dMC Configuration (Start --> Programs --> dbPowerAmp Music Converter --> Configuration --> dMC Configuration) and click "ID Tag Options". Change the setting for mp3 to "ID3v2 & ID3v2".
    What is probably happening is that dMC is writing SmartAPE2 tags and the program your using to read tags cannot read that. ID3v1 has a maximum character limit and you appear to be hitting it.
    • neilthecellist
      • Dec 2004
      • 1288
      What about the other mp3 tag level? (can't remember the name at the moment)
      • ybw89
        • Apr 2005
        No i right click on the file and enter into the properties
        and its cut off there too
        the current setting are 'ID3v1'
        Well is there anything else i can do
        • neilthecellist
          • Dec 2004
          • 1288
          screenie? (upload on http://www.kytec.com for best results)
            Change your tag settings to "ID3v1 & ID3v2". As I said, ID3v1 has a character limit.
            Also, if you'll click the "Advanced" button on the file properties page, you can put in the longer track name.
            • neilthecellist
              • Dec 2004
              • 1288
              Is ID3v1 more popular than ID3v2, LtData? Or are they both just as popular?
                ID3v2 is the newer standard and designed for longer tags and more tag fields. Dunno about popularity.
