dB power amp vs Exact audio copy
  • Qwaz
    • Jan 2005
    • 23
    is dBpower amp as good as Exact audio copy at extracting perfect files?
    and does it re-read files and compair the results to see if they are the same.... just like exact audio copy
    EAC site - http://www.exactaudiocopy.de/
    im just wondering cos i always use dbpoweramp to rip CDs
    Re: dB power amp vs Exact audio copy
    EAC is normally your best best for hard-to-rip CDs, but use AccurateRip to see if some of your CDs ripped properly: http://www.accuraterip.com
    • neilthecellist
      • Dec 2004
      • 1288
      on that page, it says that Exact Audio Copy uses AccurateRip too....um, so wouldn't both be the same??
        Originally posted by neilthecellist
        http://www.accuraterip.com/software.htm
        Yes and no. Yes they both use AccurateRip, but dMC will usually rip faster. Also, I find CDGrab easier to use than EAC.
        • Wayne
          • Aug 2002
          • 1254
          Also EAC will not use AccurateRip with some of its ripping options. I would only use EAC if I came across a CD that dMC couldn't handle.
          Wayne
          • neilthecellist
            • Dec 2004
            • 1288
            makes sense.
