Ripping Problem
  • MusicLuver2002
    • Jul 2002
    Ripping Problem
    I've been using the music converter for along time now.
    I put a cd in to rip and now it doesn't see the cd anymore?
    I tried different cd's and still nothing.
    So I uninstalled DMC and reinstalled....still won't see that there is a cd in there waiting to be ripped.
    This is what my dMC Configurations says;
    I have release 9a
    I have PowerPack release 3
    I am registered
    Auxilury Input NOT installed
    Did I forget to reinstall something or do I need to change some sort of setting? I use Windows ME in case you need to know that.
    Seems odd that it's worked great for months and now it just stopped recognizing that I put a cd in?
    Thanks for any help you can offer,
    Vicki
    • 46219
    It is likely something called ASPI has stopped working.
    First load audio cd input >> Options and see if you can select your CD drive.
    If not click on Support above >> Audio CD Input and go down to the section on ASPI.
    If you want there is a special Windows ME vxd you can install also in the support section.
    • musicluver2002
      Spoon,
      You were right, when I clicked on options....I was able to pick the correct drive. Apparently, when I just installed Nero, it changed my setting from my plextor to Nero?
      It's working great again!
      By the way, I love this dbpoweramp. I suggest this to all my friends to use
      Vicki
