I'm able to drag the files into Hymn and drop the proctection on the MP4, but when i try to convert it with DB it's giving me a windows error :(
Problem Converting Mp4 to Mp3
Re: Problem Converting Mp4 to Mp3
Have you installed the decoding codec for mp4 from Codec Central?Originally posted by ChiI'm able to drag the files into Hymn and drop the proctection on the MP4, but when i try to convert it with DB it's giving me a windows error :(
And what are the inpout file specs (bits, bitrate, freq, etc) and the output file specs (type, bits, freq, etc)?[B][url=http://www.webado.net/][COLOR=Blue][FONT=Comic Sans MS]Christina[/FONT][/COLOR][/url][/B]
[COLOR=RoyalBlue]SVP, ne pas me demander du support par PM. Veuillez poster vos questions dans le forum pour le bénéfice de tous.[/COLOR] -
Can you play the files that Hymn outputs?Originally posted by ChiI'm able to drag the files into Hymn and drop the proctection on the MP4, but when i try to convert it with DB it's giving me a windows error :(Lt. Data
Please don't PM me for tech support.Comment
Yea i have the decoder installed.
It comes in as an Itune File from Itunes so im not sure of the bitrate,etc.. but when i convert it through Hymn (I just drag it into Hymn shortcut, I guess thats how u do it)
Extension .M4a
Freq. 44100
Bitrate 128
Codec AAC
Then I get the convert to tag when i left click i try to convert to Mp3 and it gives me a windows error: Im running XP Home Sp2
AppName: musicconverter.exe AppVer: 6.0.0.2 ModName: mp4.dll
ModVer: 4.1.4.2 Offset: 000017c7
is the error i get
The funny thing is I did another song last week that came from Itunes unprotected and coverted it without a problem.Comment
Can you play that mp4 file?Lt. Data
Can you play the m4p protected file in Itunes?
Apparently Hymn isn't able to remove the copy protection then. It seems that Apple changed the version or some other aspect of the copy protection to prevent Hymn from working. You can always try dMC Auxilary Input to record the song to wav as you have Itunes play the song.
Aux. Input Instructions: http://forum.dbpoweramp.com/showthread.php?t=5362Lt. Data
You can try what is suggested at http://forum.dbpoweramp.com/showpost...9&postcount=80 .[B][url=http://www.webado.net/][COLOR=Blue][FONT=Comic Sans MS]Christina[/FONT][/COLOR][/url][/B]
[COLOR=RoyalBlue]SVP, ne pas me demander du support par PM. Veuillez poster vos questions dans le forum pour le bénéfice de tous.[/COLOR]Comment
Found a better way. I tried the plugin, but it made the song sound bad after being recorded. So i let Itunes burn a disc, which converted the files to CDA's then i opened that with another program, Creative Media Source (GF has a Zen Mirco whole reason im doing this for her) then i was able to convert he CDA's to Mp3's on the disc and BAm it was done then i copied them to the Zen.
Thanks for the speedy responces fatest ones ive gotten on any board besides a flame lol
BTW: Great Job on the Audio Player :smile2:Comment
LOL, if you did manage to burn an audio cd from iTunes, then dMC Audio CD Input would have ripped it and converted to anything else :DOriginally posted by ChiFound a better way. I tried the plugin, but it made the song sound bad after being recorded. So i let Itunes burn a disc, which converted the files to CDA's then i opened that with another program, Creative Media Source (GF has a Zen Mirco whole reason im doing this for her) then i was able to convert he CDA's to Mp3's on the disc and BAm it was done then i copied them to the Zen.
BTW: Great Job on the Audio Player :smile2:[B][url=http://www.webado.net/][COLOR=Blue][FONT=Comic Sans MS]Christina[/FONT][/COLOR][/url][/B]
