Installation problems
  • John Devoil
    • Dec 2004
    I downloaded the dBpowerAMP package and installed them on a PC under Windows 98se (Music Converter (rel 11), Power Pack, Audio Player, and codecs for Flac & monkeys audio). All worked fine, a nice piece of software (could have a couple of "wish-list" items regarding options for displaying large music libraries). After the Power Pack option expired I registered it, downloaded a package to install over the existing installation as instructed, all appeared to be fine, but I discovered a couple of features which used to work but which now do not, tried uninstalling and then re-installing, made no difference. Problems found so far:-
    1) The Options panel on Audio CD Input allows you to change the folder to rip to, clicking twice on [Set] bring up a panel for browsing through the discs and selecting a folder. This no longer works (but can type in new folder name in the box above the pull-down list).
    2) When playing a random (or selective) selection from the music library the player now stops playing at the end of each track, a further random track can be selected after hiting the skip button.
    The files downloaded and installed were: dBpowerAMP-r2.exe & dMC-r11-Registered.exe
    Any suggestions for fixing this?
    regards,
    John
    Re: Installation problems
    For your first problem, I am at a bit of a loss. Did you install the Windows 98 system updates (I am lead to understand that Windows 98SE needs these as well)? If not, go here: http://www.dbpoweramp.com/Windows95-Update.htm and download and install the 2 system files for Windows 98. Restart the computer. See if that makes any difference.
    For #2: Upgrade to release 3 beta of dBpowerAMP Music Converter (available from the beta test section of the forum here:
    Good luck and best wishes,
    Bill Mikkelsen
      For dAP make sure that crossfade is off, and try the other output to option (dAP Options Menu >> Amp >> Output to).
