Need Help Asap
  • nebula-essence-
    • Sep 2004
    Need Help Asap
    Is there a codec for converting midi files. Plz let me know asap. I just got a new midi keybored and made a few songs that i want on the go but i cant convert them. If you know were i can get one plz let me know by email. Im not gonna keep checkin back here for a response. Incase u cant find my email or if it is blocked or sumthin (im new so i dont know how things work around here) it is [email protected]
    Re: Need Help Asap
    There is no codec for midi. Check FAQ at http://forum.dbpoweramp.com/showthread.php?t=2213 or the more general http://forum.dbpoweramp.com/showthread.php?t=5362
    You have to check the forum or fix your profile to email you when there are new posts in a topic that interests you.
    • Craze
      • Oct 2002
      • 308
      Re: Need Help Asap
      Looks like Christina has already given you great information.
      Thought I'd throw this out there. If you're just wanting to create an audiofile of your work, your best bet is to just plug the keyboard directly into your computers "Line-In" connection from the keyboards stereo headphone jack and then use the Auxiliary Input to record the file. It works great with piano keyboards. Good luck with the songs you're making. Its a lot of fun.
      -Craze
      • Razgo
        • 2532
        Re: Need Help Asap
        it depends on your keyboard. mine has 2 stereo line outs and 2 mono line outs and midi thru and midi out. so for midi out i just use midi out cable to midi in the back of the sound card, which is usually the game controler port.
        you must have used some software for the recording? if your going to use multitracking you will need multitracking software. or for simple recording tunes then yeh auxiliary input will do. it can be found here: http://forum.dbpoweramp.com/showthread.php?t=2424
          Re: Need Help Asap
          I'd just add a bonus of getting the midi file into the computer from the keyboard using the midi/joyustick port: you can run that file through various midi composition programs (e.g. Anvil Studio or any from Voyetra )and modify it or print score sheets from it, a great tool for musicians.
          Of course, storing the original midi file on the computer has also the advantage of a very small size.
          Recording from the midi keyboard through the midi input may not give great results later on playback from the pc if you don't have as good and varied a midi soundbank as the keyboard. In that case recording through line-in captures it all as intended.
          • nebula-essence-
            • Sep 2004
            Re: Need Help Asap
            thnx for all the help guys. things turned out great.
