Problem ripping to iTunes AAC
  • hamman
    • Aug 2004
    Hi everbody, I'm new to this forum and just wanted to start with praising this wonderful software!
    Since I am planning to get an iPod i wan't to encode my cds to aac. I've used to rip my cds using iTunes, but it is big and slow. Plus I wan't to be able to encode from lossles (flac) in the future (read: when I can afford to get a bigger hdd). dMC seemed to fit my needs perfectly. So I installed it along with the iTunes codec. iTunes and QuickTime(6.5.1) are installed on the system. When I try to rip a cd it rips the cd succesfully, but when the encoding is supposed to start a error message pops up:
    "Line 2: run c:\\Program Files\\QuickTime\\QuickTimePlayer.exe c:\\~temp.wav. Error: Unable to run program. (Ensure that backslashes \ have been used properly"
    Well, QuickTimes directory on my computer is C:\Program\QuickTime. I tried to reinstall it to change the directory to Program Files, but there was no such option in the installer. I have specified the location to the encoder in dMC, reinstalled all of the software mentioned above several times, no luck.
    I hope you can help me and I apologise for my spelling
    Re: Problem ripping to iTunes AAC
    My first guess is that while you have dBpowerAMP Music Converter (dMC) installed, you might not have installed the codecs required to perform your conversion. dMC codecs are available from the Codec Central link in the QuickLinks box at the top of this page.
    You will want (I think) the AAC/mp4 decoder, the Psytel AAC encoder and the AAC enc add-on, the Quick Time mp4 encoder and the AAC>mp4/mp4>AAC encoder. Download and install these to their default locations. (You can find the dMC FLAC codec at codec Central as well).
    If thiis does not address your problem or if these measures don't help, please let us know.
    Bill Mikkelsen
      There is a ini file that is installed with the dMC Apple codec - edit it with notepad and change the path.
      • hamman
        • Aug 2004
        Spoon: There is no .ini file present in the dMC directory. I did a windows search for *.ini files changed during the last week, but none of the search results seemes to match. Do you know where the file is supposed to be located?
          It might not be .ini (I am away can cannot check), it will be in:
          dbpoweramp\Compression\some itunes folder
          • shallowhal
            • Mar 2005
            I have a question. If I get itunes music from a friend, what exactly in laymens terms do i need to convert the MP4 itunes music to MP3 format. Please help.
            thanks,
            Hal
            • Tomb
              • Jun 2003
              • 146
              thanks,
              Hal
              Read the FAQ
