conversion problem
  • Smoggy
    • Feb 2005
    • 120
    Re: conversion problem
    Tried it out, and couldn't get it to work...Oh well
    Thanks anyways Christina!!
    Smogg
      Did you use as a CLI? Did it ask you to locate the program? I think this is what happeend one time I tried using one of these (what I call) non-standard things. Now I dont' quite remember, either I browsed until I found it and it worked that way, or in fact I had to move the program to the proper folder where it was looking for it - memory's too fuzzy on that LOL!
      • Smoggy
        • Feb 2005
        • 120
        Yeah, I had it located in the right spot and it actually started trying to convert. I ended up with a 1 second mp3 that was just a static.
        I also found a demo version of mp3enc31.exe but that gave me the same results.
        Smogg
          Oh! can't say that I remember how it went (if ever it did) as I don't :D
          Wait, I just tried it and it worked fine. Maybe it's a problem with your input file's parameters and the selection of mp3 output file paramaters.
          I started with a normal uncompressed PCM, 44.1KHz, 16-bit, 2ch stereo wav and converted to mp3 using that program, 128kbps and quality 9. No problem really. The result was joint stereo.
          • Smoggy
            • Feb 2005
            • 120
            hmmmmm...Ok i'll try messing around with those settings
            Smogg
            • Smoggy
              • Feb 2005
              • 120
              #21
              Got it to work at 128kb only though......I was trying 256kb before.
              Looks like its the same demo version I have.....It's restricted to 30 sec of conversion. Blah!!!
              I need to find a hacker for hire...LOL..unlock my other encoder.
              Smogg
              • neilthecellist
                • Dec 2004
                • 1288
                #22
                don't talk about hacking here.
                my AIM s/n: Neil the Cellist
                my email address: neilthecellist@gmail.com
                • Smoggy
                  • Feb 2005
                  • 120
                  #23
                  oops, hit the back button!
                  Smogg
                    #24
                    Hmmmm... you're right. Id' not noticed that. Oh, welll....LOL
                    It's also rather lousy quality. I can get a much better sounding mp3 128kbps joint stereo from Lame.
                    • Smoggy
                      • Feb 2005
                      • 120
                      #25
                      What are the optimal settings for the best quality Mp3? File size not being a factor. I've been using "alt insane"
                      Smogg
                        #26
                        If file size isn't a factor, do 320kbps Joint Stereo
                        As for presets, I can't really help.. don't know them, as I don't use mp3 on a regular basis.
                        • Smoggy
                          • Feb 2005
                          • 120
                          #27
                          is 48000hz better than 44100hz? What is exactly the difference?
                          Smogg
                            #28
                            For CD, keep it at 44100Hz. CDs are sampled at this rate and you increasing it to 48000Hz will not improve the sound and may actually make it sound worse.
                            The difference is the amount of time each second the sound is sampled. Most computer sound cards can reproduce both frequencies the same, but a few cards work best with 48KHz. (48KHz = 48000Hz)
                            • Smoggy
                              • Feb 2005
                              • 120
                              #29
                              Ahhh IC
                              Smogg
                              • neilthecellist
                                • Dec 2004
                                • 1288
                                #30
                                Personally, I would only do 48 khz if I'm MAKING the audio (e.g. microphone/recording sound using Auxiliary Input) because I tend to think that the audio sounds better.
