HELP! Cant convert cd into mp3 lame HELP!
  • phonesupplies4u
    Heres error i get,
    im using a scsi ultraplex 40x drive i dont know if this helps, ive tried all the codecs the program comes with - still no go.
    Its part of a benchmark test im running, it uses this program to see how good your cpu and cd drive are. Please help.
    CODEC decompression error for '\\CdRom\Track01.cda'
    Unable to Rip track - make sure correct Ripping method is selected and CD Drive supports digital audio extraction.
    CODEC decompression error for '\\CdRom\Track02.cda'
    CODEC decompression error for '\\CdRom\Track03.cda'
    CODEC decompression error for '\\CdRom\Track04.cda'
    CODEC decompression error for '\\CdRom\Track05.cda'
    CODEC decompression error for '\\CdRom\Track06.cda'
    CODEC decompression error for '\\CdRom\Track07.cda'
    CODEC decompression error for '\\CdRom\Track08.cda'
    CODEC decompression error for '\\CdRom\Track09.cda'
    CODEC decompression error for '\\CdRom\Track10.cda'
    CODEC decompression error for '\\CdRom\Track11.cda'
    CODEC decompression error for '\\CdRom\Track12.cda'
    CODEC decompression error for '\\CdRom\Track13.cda'
    CODEC decompression error for '\\CdRom\Track14.cda'
    CODEC decompression error for '\\CdRom\Track15.cda'
    CODEC decompression error for '\\CdRom\Track16.cda'
    Do i need a special codec for scsi ?
    Re: HELP! Cant convert cd into mp3 lame HELP!
    Which windows version?
    • metlheart
      • Dec 2005
      Did this problem ever get solved? The reason I ask is because now I get the exact same errror message.....out of nowhere. It worked fine yesterday, won't do crap today. So far, my experience with the registered version of dMC Audio Cd Input has been far less than satisfactory.
        First, we need some more information about your problem:
        What OS are you using? Is your CD drive also SCSI or is it IDE? What version of dMC are you using? What is the command set for your CD drive (Options --> CD drive Advanced)?
        Can you convert the songs using dMC itself, not the CD ripper?
