CD input - no tracks - Aspi problem???
  • cmmehl
    • Oct 2002
    Howdy all,
    starting Audio CD Input (version 10.1), the only thing I see is "insert audio CD".
    I have tried the settings under options, "Aspi" doesn't show my drives at all, "2000/NT built-in limited" shows the drives letters only and "Device IO" shows them by letter and name.
    I have tried every single setting with "Device IO", no result, nothing shows, even after refresh.
    I have tried all the recommendations in the support section, made an aspi-dump and aspichk tells me all is fine, and the spoon-checker also recognizes both my drives. And yes - I rebooted to test all this.
    Running XP-Pro, Toshiba DVD-ROM SD-R5112 and NEC DVD_RW ND 1300-A.
    I recently installed a Highpoint Rocket Raid (hpt 374), could that be the problem?
    Oh yes, and if I select the tracks from the explorer, they convert fine and fast, it's only in the Audio CD Input program that I don't see any tracks.
    Help me pls!
    Chris
    Re: CD input - no tracks - Aspi problem???
    If you select Audio CD Input >> Options and change the CD drive to the other drive does it show the tracks?
    (you will almost certainly need the MMC option in advanced).
    • cmmehl
      • Oct 2002
      Thx Spoon for answering.
      No it doesn't.
      Not with MMC nor anything else.
      • cmmehl
        • Oct 2002
        Mea culpa!!!
        Spoon, so sorry - false alarm ...
        I'm ashamed to admit it ... :headbang: the CD in question was already in mp3 format :( no wonder it didn't work ...
        All works fine, as usual.
        Pls forgive me!
        Chris
