Audio Stutters after conversion
  • joeyz1998
    • Jan 2022
    I'm converting m4a to mp3 on Apple M1Max with macOS 12.1 Monteray.
    After conversion, the audio in the new track is stuttering a lot, completely unlistenable. I've tried batch converts, but also single files. And als o I've tried turning off all other applications. Not sure what to do, thanks.
    • 45916
    Re: Audio Stutters after conversion
    What is your player? try iTunes
    • joeyz1998
      • Jan 2022
      I've used iTunes to play back audio. Also I've just used the default music player when you press spacebar while the file is highlighted in finder.
      I had to resort to converting the songs to mp3 via iTunes built in converter. So I know the issue must lie with dbpoweramp.
        • 45916
        What exact settings did you use for mp3 conversion? Which version of dBpoweramp do you have?
        • jrmach
          • Apr 2011
          • 39
          Sounds like the same issue I am having with db converter? I used free audacity to convert my m4a files from itunes with no issues. see post (Converted files cut out)
          • jamescobbinlee
            • Mar 2022
            I'm having similar issues - on my Windows 10 Enterprise it appears that DB Poweramp is unable to effectively convert MPEG-4 files that have been encoded with AAC - my current workaround is to convert them to Apple Lossless before using DB Poweramp to convert them to FLAC. Cumbersome. Is there a known fix?
              • 6169
              see post 17
              I purchase my music from iTunes, and this week I have noticed when I convert using batch converter, all the songs from one of my albums cut out a lot on every song. I made a new purchase tonight just to test it again, and it converted fine. Anything I should be checking?
              • jamescobbinlee
                • Mar 2022
                Thanks so much for that - problem fixed. In appreciation.
