FreeDB problem
  • jtdavies
    • Feb 2004
    • 13
    FreeDB problem
    I can get CD info from FreeDB.
    However the problem occurs when I try to submit information. Then I get a could not connect message.
    When I try to configure the server, the program hangs for minutes then eventually brings up a dialog box.
    I'm behind a Linksys home firewall. Is there anything different between retrieving and submitting FreeDB info?
    • 46171
    Re: FreeDB problem
    Yes, firewalls can block ingoing and out going seperately.
    When you config the server, what is the message is shown?
    • jtdavies
      • Feb 2004
      • 13
      Re: FreeDB problem
      When I config the server, it acts like it should bringing up the dialog box. The only problem there is that it is extremely slow to open the dialog box.
      When I try to submit to freeDb I get:
      Unable to connect to freedb server, please cehck your internet connection.
      On another machine on the netwwork this doesn't happen. It goes right through.
      So if it is a firewall issue then it is the built-in XP firewall. They are both running XP Home.
      • Wayne
        • Aug 2002
        • 1254
        Re: FreeDB problem
        I think you'll find that the XP firewall only stops incoming traffic not outgoing.
