Mistake setting bit depth and Sample rate
  • offtheroad
    • 48
    I mad a mistake converting flac to aiff with my bit depth too high and sample rate too high. I should have left the setting to " same as source" I no longer have the flac files. How is this going to hurt the files and is there any way to remedy the problem if there is any? Thanks
    • 45594
    Re: Mistake setting bit depth and Sample rate
    You can convert back down to what they were before, however sample rate conversions are a lossy process so will no longer have bit identical files.
    • offtheroad
      • 48
      Thanks for the response. Will I get better sound quality if I do this or just smaller file?
        • 45594
        Just smaller file.
