problem with Folder.jpg (cover art export)
  • rory
    • Jul 2016
    no cover can be saved on the disc
    just have a look. is it possible to fix?
    win10 x64
    • 45836
    Re: problem with Folder.jpg (cover art export)
    Which version of dBpoweramp do you have? which encoder are you using?
    • rory
      • Jul 2016
      release 16 [x64]
      suppose so encoder is not a point, just I can't save a cover on the hard disc utilizing tag editor
      other encoding functions work more or less acceptable.
        • 45836
        You are trying to save album art by right click on a track >> edit ID Tags >> ... menu >> export to folder.jpg?
          • 1897
          Can you create i.e. a text file in that folder?
          • rory
            • Jul 2016
            Better to see once than to write 100 words
ID:	293186Click image for larger version
ID:	293187Click image for larger version
ID:	293188Click image for larger version
            holding on to you
              [ATTACH=CONFIG]1024[/ATTACH][ATTACH=CONFIG]1025[/ATTACH][ATTACH=CONFIG]1026[/ATTACH][ATTACH=CONFIG]1027[/ATTACH]
              As the error states, either your disk is full, so there is no room to save the file OR access to that folder is denied and you do not have the necessary file permissions to save to that folder.
              In post no. 5, Dat Ei has already asked a (very relevant) question and it would help us to help you if you could answer that question. Also, what OS/platform are you using?
              • rory
                • Jul 2016
                gentlemen, which folder you're talking about? I always save all pics files onto desktop in cases like that and everything's going ok. do you think I haven't access for Desktop folder? impossible. dbpoweramp even doesn't ask me: where I want to save the cover? just - see my pictures above.
                and I repeat, my system - windows 10 pro, x64.
                well, tight squeeze ...
                  • 45836
                  The export writes to the same folder your music files are. A simple test is to create a new folder:
                  c:\test
                  copy those tracks to that folder and try the export. It is Windows which is stopping dBpoweramp from writing to the other folder, there is nothing dBpoweramp can do to change that.
                    I am unsure which folder the Export to Folder.jpg command defaults to, but it is probably the same folder as the audio file you have selected when selecting the Edit ID-Tag command. ... OK, this is now confirmed by Spoon's post above.
                    The error message is your clue here. First, confirm your disk is not full. Second, does the Windows user account have administrator permissions?
                    Last edited by mville; August 02, 2016, 10:25 AM. Reason: added confirmation for Export default folder
                    • rory
                      • Jul 2016
                      Disk free space 250 gb. 'tis my computer, it's me who's admin. You see, small TagScanner saves any cover art from tags like a breeze, so I can't figure out why dbPoweramp doesn't?
                      but Thank you in any case for your attention.
                        • 1897
                        And you have the write permission for the folder, where your source files are?
                          Did you try the test in Spoon's post no. 9? What was the outcome?
                          • rory
                            • Jul 2016
                            just have tested. oddly, but it works, but in root directory only (C:/), in other places it doesn't work for whatever reason. maybe I should give up on the bug...
                              Are the other (places) folders, local folders i.e. are they located on the C: drive or another drive on your PC?
                              What antivirus/security software are you running, if any?
