Converting speed different for V0 and Cbr 320.
  • Music Junkie
    • Jul 2016
    I'm converting some of my Flac files into mp3 at V0 vbr, using slow speed (Best Quality) and the Speed for single file is 54x. But when I convert a flac file to mp3 320 cbr, the conversion speed is 10x by using slow speed (Best Quality). Am I compromising with quality by using V0 vbr, if 320 cbr is more slower while converting. Please help! I want to keep on using V0.
    I'm Using dBpoweramp Release 16.
    Re: Converting speed different for V0 and Cbr 320.
    CBR 320 is the highest possible quality, as reflected by the cpu usage encoding it.
    • thexfile
      • Jul 2010
      • 177
      Lossy is Lossy.
      VBR V0 at slow speed or CBR 320 at slow speed will sound the same. VBR is an efficiency improvement to CBR.
      To save space I recommend VBR V0.
      • Music Junkie
        • Jul 2016
        Hey Spoon, Thanks for the info. V0 sounds almost precisely the same as 320. So, do you recommend using CBR 320? I will do what you say. I'll be waiting for your suggestion.
          They are both very good, personally I would choose V0
          • Music Junkie
            • Jul 2016
            Thank you so much Spoon. I will be using V0 from now on. I am very much satisfied with your product.
            YOU DA MAN!!
