Strange Sound
    Strange Sound
    When recording from audio tapes with Auxiliary Input I get a short blip io music after the end of each recording!! Any ideas on what is causing this??
    thanks Nick
    Re: Strange Sound
    What file format are you recording to?
      Re: Strange Sound
      Hi Spoon,
      I am recording in wave format there is about a half sec delay then the blip of sound!!
      Regards Trev
        Re: Strange Sound
        Do you call a blip something where half a second of sound is missing, or some other noise?
          Re: Strange Sound
          Hi Spoon Thanks for you reply At the end of the recorded track there is about half a second of silence then half a second of what sounds like music??
          regards Trev
            Re: Strange Sound
            and you are using the AutoStart and AutoEnd options in AuxInput?
              Re: Strange Sound
              Yes that is right ...it does not do it if I stop the recording manually???
                Re: Strange Sound
                Try shortening the AutoEnd Time.
                  Re: Strange Sound
                  Yes I have tried a number of different settings but run into truble with false stops and starts... I have solved the problem by putting a 200ms trim dsp effect on each track.
                  I congratulate you on an excelent program... Thankyou for your help
                  Regards Trev
