converting mp3 to wav problem
  • Anne Akridge
    • May 2014
    • 9
    when I convert an mp3 to a wav the wav for lack of another way to describe sounds like chipmunks singing and words can't be understood. I've been converting for a long time then suddenly one day this event happened. I deleted dbpoweramp from my system and re-installed and re-registered but didn't fix the problem. Would appreciate a solution because dbpoweramp is the BEST when working right. Also these bad converted wavs won't play with Windows Music Player. Thanks.
    Re: converting mp3 to wav problem
    What are the settings for the wave file?
    • Anne Akridge
      • May 2014
      • 9
      dot in mp3-wave
      settings on next screen are
      48 kbps
      Bit Rate (CRB)
      Encoding Normal
      the advanced settings says
      Frequency (as source)
      Channels (auto)
      and check mark in original
      all else blank
        Try as uncompressed wave, then play it back, how does it sound?
        • Anne Akridge
          • May 2014
          • 9
          Thanks for your quick response, Spoon, and willingness to help!
          I was surprised when I found a paper where I had written down my previous settings and now all is fixed and converting well.
          Sharing the settings with you below that work for my converting mp3 to wave.
          64kpbs
          slow (high quality)
          bit rate (CBR)
          Advanced settings
          Original
          44.1 KHz (CD)
          2 stereo (auto) (CD)
