Right Click menu 'Convert to' and 'Edit ID tag' Won't Show for FLAC
  • Hectic
    • Oct 2010
    Basically I'm having the problem that's stated in the title. When I right click on a FLAC, it won't give me the options to "Convert to" another format or "Edit ID tag(s)". Even when I go into properties it doesn't have a ID tag tab. I don't have this problem with any other file format (ALAC, AIFF, MP3, AAC, WAV, etc.). At least I can actually load up the Music Converter and select the FLAC files I want to convert that way, but having the options to do these things in the Right Click menu (especially the ID tag edit) would be very handy to have. Any way to fix this? I am currently using v.R15.3 and am running Windows 7x64. Thanks!
    • 46085
    Re: Right Click menu 'Convert to' and 'Edit ID tag' Won't Show for FLAC
    Windows will exclude some items from the right click if there are too many showing, how many 3rd party ones do you have for
    Flac?
    • Hectic
      • Oct 2010
      None. I can right click on a MP3, ALAC or any other sound file and it will give me the usual stuff I have including the DBpoweramp right click menu stuff, but when I do it for FLAC it gives me everything else BUT the stuff for DBpoweramp. The only 3rd party software that I can think of that may be interfering is MP3tag?
        • 46085
        Run Configure dBpoweramp to reinstate the right click menus. If still no go, configure so no 'Convert To' or Edit Tags on Right click, then full shutdown of Windows, then add once starts.
        • Hectic
          • Oct 2010
          Yup, that did it. I can't believe it was something SO simple. Thanks!
