Issue while converting FLAC to WAV --> noise between tracks
  • Laval
    • Mar 2015
    • 11
    Hi, I am wondering how to fix the following issue: I have converted FLAC to MP3 w/o any issue. When doing the same from FLAC to WAV, I have a 1 second "big" noise between each track which is not very good while listening the music!
    Any idea how I could fix the issue?
    Many thanks,
    Laval
    I am on Windows 7
    • 4015
    Re: Issue while converting FLAC to WAV --> noise between tracks
    What player are you using?
    I suspect the player is unable to read wav files that contain metadata.
    You have to disable the Wave ID Tagging in dBpoweramp Configuration>Codecs>Advanced Options. Try it and see if the noise disappears.
    • Laval
      • Mar 2015
      • 11
      it is actually in my car, using a USB3.0 stick (Mercedes, 3years old);
      ok thank you, I am trying now and I tell you the result.
      So in the Wave ID Tagging, for Tag Creation, i have selected (none), instead of initially (default - LIST & ID3)
        • 4015
        correct
        • Laval
          • Mar 2015
          • 11
          it works fine now! Many thanks!
          So, what type of metadata I am losing with this new set-up?
            • 44040
            All metadata, your wave files are untagged.
            • Laval
              • Mar 2015
              • 11
              I am sorry, what does it mean?
              For example, I still see the album, artist and track names
              • Nexus6
                • Nov 2014
                Many thanks,
                Laval
                I am on Windows 7
                hi dear laval
                why do you wanna or try because it will not work or better yet, you will not hear a difference in audio quality just enlargening the file/song/track , probably there lies your problem , as you can hear that from flac to Mp3 ,did a good job , as seen here
                but good luck , with your problem
                Win 8.1 64 bit
                  • 5758
                  It may be that the car player reads the file names (as opposed to the metadata) of your files (and these may contain album, artist, track names).
