Issue while converting FLAC to WAV --> noise between tracks
  • Laval
    • Mar 2015
    • 11
    Hi, I am wondering how to fix the following issue: I have converted FLAC to MP3 w/o any issue. When doing the same from FLAC to WAV, I have a 1 second "big" noise between each track which is not very good while listening the music!
    Any idea how I could fix the issue?
    Many thanks,
    Laval
    I am on Windows 7
    Re: Issue while converting FLAC to WAV --> noise between tracks
    What player are you using?
    I suspect the player is unable to read wav files that contain metadata.
    You have to disable the Wave ID Tagging in dBpoweramp Configuration>Codecs>Advanced Options. Try it and see if the noise disappears.
    • Laval
      • Mar 2015
      • 11
      it is actually in my car, using a USB3.0 stick (Mercedes, 3years old);
      ok thank you, I am trying now and I tell you the result.
      So in the Wave ID Tagging, for Tag Creation, i have selected (none), instead of initially (default - LIST & ID3)
        correct
        • Laval
          • Mar 2015
          • 11
          it works fine now! Many thanks!
          So, what type of metadata I am losing with this new set-up?
            All metadata, your wave files are untagged.
            • Laval
              • Mar 2015
              • 11
              I am sorry, what does it mean?
              For example, I still see the album, artist and track names
              • Nexus6
                • Nov 2014
                Many thanks,
                Laval
                I am on Windows 7
                hi dear laval
                why do you wanna or try because it will not work or better yet, you will not hear a difference in audio quality just enlargening the file/song/track , probably there lies your problem , as you can hear that from flac to Mp3 ,did a good job , as seen here
                but good luck , with your problem
                Win 8.1 64 bit
                  It may be that the car player reads the file names (as opposed to the metadata) of your files (and these may contain album, artist, track names).
