R15.1 Encoder info in info panel?
  • chrisjj
    • Nov 2008
    • 300
    How do I get these Audio Properties
    to show in the info panel:
    please?
    • 46230
    Re: R15.1 Encoder info in info panel?
    I not think it is possible, that bottom panel, it is not dbpoweramp which is supplying the info, it is Windows.
    • chrisjj
      • Nov 2008
      • 300
      I thought it was the dBpa Windows integration feature described in Help:
      Thumbnail and Property Handler
      dBpoweramp enables Windows to work with file types it does not natively support, such as FLAC. Album art is show and tag editing is possible from Windows File Explorer:
      Are you saying this integration has failed somehow?
        • 46230
        For WMA windows is using its own.
        • chrisjj
          • Nov 2008
          • 300
          OK, thanks. Is there any way I can get Explorer to use dBpoweramp for that?
            • 46230
            Not that I am aware.
            • chrisjj
              • Nov 2008
              • 300
              OK, thanks.
