Music Converter R15 not showing "edit ID tags" on right-click
  • dk8260
    • Sep 2014
    Re: Music Converter R15 not showing "edit ID tags" on right-click
    Edit ID-Tag still doesn't work in V15.2, if I run v15.2 in x86 mode on Windows 7 x64.
    Right-click displays the "Edit ID-Tag" button, but nothing happens when I press the button.
    • Thg6276
      • Aug 2008
      • 187
      #47
      Bonjour
      i have the same issue since yesterday.
      No Shell edit mode
      uninstall / reinstall : same thing
      How to do a ran dbpoweramp reset as mentionned in previous page of this thread ?
      • BrodyBoy
        • Sep 2011
        • 780
        #48
        dBpoweramp reset utility
        Save the file (rather than "Run"), then right click on the downloaded file and "Run as Administrator."
        • Thg6276
          • Aug 2008
          • 187
          #49
          Thank You
          Problem yesterday with dBpoweramp, impossible to have metadata of one CD (Patti Smith/Horses) and software totally freezed.
          Uninstall/Reinstall of DBP and cleaning of the computer with Ccleaner (cleaning of Windows Registry included)
          I think that cleaning of registry with Ccleaner was not really a good idea
          So, after "no edit ID-tag", and "convert to" on right-click ... has disappeared !
          In fact, fixed this evening after have used the Windows Restore Points
          All is OK now
          • albaranov
            • Apr 2011
            • 13
            #50
            Today I installed the 15.3 version and since then have the same issue about audio properties.
            Every time I try to use right click with DSF files, the pop up window says: Provides Audio Information for dBpoweramp has stopped working.
            It NEVER happened with the previous versions of dBp.
            Also used the reset tool, no difference.
            System: Windows 7 Pro (64)
            Files: DSF (FLACs are O.K. the right click works with FLACs)
            DSD decoder installed
            Installed/uninstalled/re-installed dBp five times, every time re-booting Windows.
            Would appreciate a word of wisdom.
            Thank you,
            Alex
              • 46370
              #51
              The program is crashing, so a reset will not help. Please upload one dsf file to dropbox and provide a link by email:
              • albaranov
                • Apr 2011
                • 13
                #52
                https://www.dbpoweramp.com/email.htm
                Done. The uploaded file was read by the previous version of dBp and is still read by Foobar. Thank you.
                Alex
                • albaranov
                  • Apr 2011
                  • 13
                  #53
                  Hi Spoon,
                  I have good news. Started my computer after work, checked the same file - miracle, I can access and edit the DSF file properties with a right click.
                  The only explanation that I have is the fact that I just re-installed Windows 7, and last night I installed Windows 7 SP. It appears that the service pack is critical for the functionality of dBp.
                  Thank you for all support.
                  Alex
