Music Converter R15 not showing "edit ID tags" on right-click
    • 1932
    #31
    Re: Music Converter R15 not showing "edit ID tags" on right-click
    Hey Spoon,
    Noted, will test for next beta
    that would be good, especially because I could reproduce the error with a second and a third PC (Win 7 Pro 64bit German, Windows FireWall, Avira Free Antivirus).
      • 46370
      #32
      Strange, I have taken a fresh Windows 32 bit, installed R15.1 and Convert To and Edit ID Tags are present after install.
        How about 64 bit. I've installed on my 3 win7 pro 64bit machines and see same issue on all 3.
          • 46370
          #34
          As soon as I install R15 32bit, R15 64bit or R15.1 64bit the "Edit ID-Tag" dialog opens like expected
          I think we would hear alot more about R15.1 64 bit not working with edit id tag as that is the one everyone uses. Have you tried an uninstall, reboot, reinstall?
          • Orac
            • Aug 2013
            • 15
            #35
            I too have lost the right-click integration since upgrading from R14 to R15.1 64-bit. :(
            Edit:
            Just after I posted, I was browsing the forum and found out about the dbpoweramp reset utility so ..
            I did a full uninstall, rebooted, ran dbpoweramp-reset, rebooted again then installed R15.1. My right click integration is back!
            Last edited by Orac; September 28, 2014, 08:29 AM. Reason: New information, dbpoweramp-reset.exe
            • dk8260
              • Sep 2014
              Same here, I've tried R15.1 Installed as x86 on Windows 7 x64, I have tried on three different machines of which one was new Installed.
              R15 Installed as x86 right click working
                • 46370
                #37
                Convert To is missing also?
                • dk8260
                  • Sep 2014
                  I cant remember if it was missing or did not work, I instaler R15 x86 on Windows 7 x64 and everything was fine
                    I just did the ininstall, reboot, reinstall 15.1 on my win7 64 machine. No change. In my case, I only see the right click options of "edit ID tag" or "convert to" if I'm within a subdirectory and select the music tracks themselves. If I'm at the ARTIST directory or ALBUM subdirectory level, on right click (of one of these folders) I can only see the "batch convert" option (and not the edit id tag or convert to). It seems like in prior versions I would see the edit id tag and convert to at the upper subdirectory level.
                    • pogo
                      • Oct 2014
                      Hi, Spoon, I´ve installed R15.1 on windows 7 x64, the ID tags doesn´t display bit depht for any track, when I use the converter, only when I ripper a CD, no matter the encoder I use it, what it s de problem, thanks a lot.
                      PD sorry for my bad english
                        • 46370
                        #41
                        Bit depth would not be in the ID Tags.
                        • pogo
                          • Oct 2014
                          oooh no, so bad, why not?, I would like to see it in the ID Tags, I like to know the bit depth for any track converted, so why can I do?, thanks again
                            • 46370
                            #43
                            You can hold the mouse over the file and the popup information will show the bit depth.
                            • pogo
                              • Oct 2014
                              sorry, but the popup information doesn´t show the bit depth, all the other information is ok, so I don´t know what to do.
                                • 46370
                                #45
                                For mp3 or aac there is no such thing as bit depth, the format can be decoded as 16, 24, or 32 bit.
