Problem with cyrillic letters
  • exec
    • Dec 2007
    • 53
    Hi!
    I'm converting FLAC to MP3 nad have a problem with cyrillic letters:
    These seem to 'get lost'. Doesn't matter if these are in the file name or tag, they are just replaced by question marks.
    So after converting, I have to correct the file names and/or tags manually.
    Latest dBpoweramp version on Win 7 64 bit.
    Any idea or workaround?
    Re: Problem with cyrillic letters
    Run dBpoweramp Configuration >> Codecs >> Advanced Options
    Make sure Mp3 ID Tagging:
    Tag Creation: ID3v2
    ID3v2 Text Encoding: Unicode-16
    • exec
      • Dec 2007
      • 53
      Both options enabled, but still the same problem...
        If you convert FLAC to FLAC (in a different location) the characters are correct in the new flac?
        If you hold the mouse over the new mp3 file (popup info tip) it will say which ID tag type is contained within, what does it say?
