where to set the Audio conversion speed?
  • stealer
    • Jun 2013
    the last time when I was using the trial program ...
    there was a setting where you can set you the conversion rate to the best SQ speed, which is the slowest..
    But now on the registered copy (14.3 & 14.4), I don't seem to find this setting...
    HAs this been removed or did I missed it..
    thanks
    Re: where to set the Audio conversion speed?
    Which audio format do you encode to?
    • stealer
      • Jun 2013
      I usually stored the given(from friends) format in flac or AIF but sometimes I was given in ALAC..
      even there are times, they are in APE...or from WAV to AIF
      So to ensure that they are converted accurately and maintaining the SQ, I guess one has to set it at the slowest conversion speed..
      that is what my understanding is...(hope I am right)
      thanks for the response
        All the formats you have mentioned are Lossless, they do not have quality settings as they always encode to 100% quality.
          In addition to Spoon's answer, note the above statement is incorrect (whether ripping to lossless or lossy files). It's a myth, but shows up everywhere on the internet.
          • stealer
            • Jun 2013
            Sorry,
            I am only asking to what I had remembered when I 1st started the trial program.
            I am sure that it asked to select the conversion speed during the initial installation..
            But like I said, it now not shown, regardless of the its lossless, lossy etc...
            Anyway, thanks for the response..
            rgds
            • BrodyBoy
              • Sep 2011
              • 780
              Sorry,
              rgds
              If you are using the Lame mp3 encoder, there's an encoding speed option in its dialogue box.
