Problem with Album Gain and R128
  • Max Dread
    • Dec 2013
    • 297
    Re: Problem with Album Gain and R128
    Not sure how the foo pod component handles it. Aren't you using that now? What does it do?
    No, I'm not using anything yet. I'm just researching at the moment and getting my strategy together. Once I have found out what foo pod does I will add it to this thread in case anyone stumbles across it in the future.
    If you use the dbpa method, and have both track and album gain, soundcheck will contain album gain value only.
    Well, in that case, I think I will leave iTUNNORM unticked. If I have to choose one gain type only for Soundcheck it would be Track, not Album. So I'll just have DBPA write the replay Gain and use something else to convert that to Soundcheck Track.
    Many thanks for the help.
    • Max Dread
      • Dec 2013
      • 297
      Plus, this might also be a good reason to no tick iTUNNORM in my situation:
      http://forum.dbpoweramp.com/showthre...nes-Soundcheck
