Problem with gapless playback after conversion
  • zzdpmjpr
    • Aug 2012
    • 9
    Hi
    I am a fairly inexperienced user of dMC.
    I have an album ripped as WMA which plays gapless perfectly in WMP12. I can't be certain what software I used to rip.
    I converted it to flac using dMC and these files play with a discernable gap or fade between tracks on WMP12. I think the codec being used in WMP is libavcodec.
    Are there any ideas as to why this is happening?
    kind regards
    John
    Re: Problem with gapless playback after conversion
    The source file is WMA Lossless?
    • zzdpmjpr
      • Aug 2012
      • 9
      Not sure how I determine that.
      It shows encoder Windows Media v12.7600.16385 and bitrate vbr1152 though in WMP it shows bitrate of 700 -900Kbps. I'm not sure if that's lossless or not.
      • zzdpmjpr
        • Aug 2012
        • 9
        Your audio properties tab does show it as lossless - see below
        [COLOR="*0000CD"]Artist Litton/Hough
        Title Rachmaninov: Rhapsody On A Theme Of Paganini, Op. 43 - 03. Theme
        Album Rachmaninov: Piano Concertos, Rhapsody
        Track 16
        Disc 1/1
        Genre Piano Concerto
        Year 2004
        Rating
        Composer
        Size 1.23 MB (60% Compressed)
        Original Size 3.03 MB
        Length 18 seconds
        Channels 2 (stereo)
        Sample Rate 44.1 KHz{CR}
        Sample Size 16 bit
        Bit Rate 1,411 kbps
        Encoder Windows Media Audio 9.2 Lossless
        Encoder Settings VBR Quality 100, 44 kHz, 2 channel 16 bit 1-pass VBR
        Audio Quality Perfect (Lossless)
        Contains ID Tag [WMA ID Tag]
        Channel Mapping
        File 09
        Type Windows Media Audio file [.wma][/COLOR]
        Above shows bitrate as 1411, Win Explorer as 1411, WMP12 700 -800 and Tag/Rename as VBR1152. Why all the differences.
        Anyway hope this helps
          Perhaps WMP cannot play FLAC gaplessly, try a player such as foobar 2000 as a test.
          • zzdpmjpr
            • Aug 2012
            • 9
            You are spot on of course - foobar plays it fine. As I'm keen to stay with WMP would a different flac codec (if there is one) make any difference?
            I am moving to upnp next month and dreading it. Will Asset play flac and WMA Lossless gaplessly?
            Your help is much appreciated
            • dbfan
              • Jan 2011
              • 937
              Asset serves wma and flac losslessly! But upnp its self is not gapless, unless the player holds the playlist on the device its self.
              • Tim De Baets
                • Oct 2010
                I don't think that libavcodec is a standalone codec but it is included in FFDShow. Do you mean that one? Other possible codecs are madFlac and those from Xiph.org.
                WMP can't do gapless playback if a DirectShow-type codec is used (which applies to all three codecs mentioned above). But it should be able to do gapless playback if you install a Media Foundation-type codec such as MFFLAC.
