MP3 comment problem
  • hamsen
    • Dec 2009
    • 21
    MP3 comment problem
    I have a mp3file with one comment containing a description.
    Like:
    TAG = COMM
    Desc = TrackNotes
    Text = This is a comment
    That shows up in dbPowerAmp correctly as:
    TrackNotes = This is a comment
    At the same time, the normal commentfield is empty.
    Also correct.
    But if I enter a value in the normal comment field, this will be written correctly, but at the same time the comment with a description is removed.
    This is not exactly, what I expected.
    Regards
    Thomas
    Regards
    Thomas
    Re: MP3 comment problem
    Will note as a possible bug.
    • nab128
      • Mar 2006
      • 64
      As far as I know dMC can only write 1 comment frame. Subsequent comments are converted to TXXX frames. This is a long standing issue.
      • hamsen
        • Dec 2009
        • 21
        http://forum.dbpoweramp.com/showthread.php?t=18899
        I didn't go that far back to look for this problem.
        That makes it so much more disapointing, that this has not been fixed yet.
        It seems to me, that bug fixing takes a very long time with dbPoweramp.
        Regards
        Thomas
        Regards
        Thomas
        • nab128
          • Mar 2006
          • 64
          It depends on the severity of the bug. This seems to be a low priority as it affects fewer users.
          Spoon, hear our cries! Please put this back on the to-do list!!
          (Also be aware that dMC writes comment frames with an illegal null language code which causes the comment to disappear in Windows Explorer. This is a trap for the unwary. Re-writing the tag with any tag editor should restore the language code.)
