Audio Lost problem
  • raj
    • Jan 2010
    Audio Lost problem
    Hi , All
    I install DBpoweramp on my system and using the windows media encoder to encode the file using windows media audio 9.2 codec. but regularly audio is lost . as I stop and start the encoding audio regain . why it is happening
    • 46167
    Re: Audio Lost problem
    Audio playback or audio as written to the file that dBpoweramp is creating?
    • raj
      • Jan 2010
      "audio as written to the file " after encoding . but audio is coming in the original stream . Windows media encoder bar is showing the audio . And I checked strictly audio is coming but not writing into the file .
        • 46167
        'Windows media encoder' this is our software or Microsofts own encoder?
        • raj
          • Jan 2010
          this is Microsofts own encoder .
            • 46167
            Our install does not touch microsofts.
            • raj
              • Jan 2010
              But I am using your codec installed by dBpoweramp-Codec-WMA10Pro.exe.
              I am using my application build by windows media encoder 9 sdk .
              I am selecting windows media audio 9.2 codec for audio encoding
                • 46167
                It is likely a bug in your application you are writing, sorry to say it is nothing to do with dBpoweramp (even if you install the Windows System Codecs through our install).
                • raj
                  • Jan 2010
                  same application is working on some computers and never loss audio but on some computers it is lost frequently . I have to stop and start the encoding process. why it is hapenning
