Batch converter won't work on flac to mp3 conversion
  • dannyauhs
    • Jan 2010
    Whenever I do a conversion from flac to mp3, I keep getting error message as follows:
    "============= CONVERSION BEGIN =============
    *** Error: Error writing audio data to StdIn Pipe [clEncoder::EncodeBlock]
    ============= CONVERSION END ============="
    This will not happen on wav to mp3 convert. Any idea how to fix it?
    I am using registered version
    Danny
    Re: Batch converter won't work on flac to mp3 conversion
    Try using the Fraunhofer mp3 encoder option.
    • dannyauhs
      • Jan 2010
      Thanks Spoon,
      Can you guide me how to pick Fraunhofer mp3 encoder option as I can only see mp3 (Lame) on the "converting to" pull down, other than wav and flac.
      Regards
      Danny
        If you have dBpoweramp Reference it is included.
        • dannyauhs
          • Jan 2010
          I have the registerd reference R13.3 but I can't find any Fraunhofer mp3 encoder. Please help
          Regards
          Danny
            It should be listed as mp3 (Fraunhofer), if you have not done so install:
            • dannyauhs
              • Jan 2010
              Thanks Spoon. Working now.
              Regards
              Danny
