Power Pack not Installed?
    Hi hopefully someone can help me with this. I downloaded and installed the Sveta Portable program. This came with the Power Pack and DbPowerAmp itself and I allowed these to install aswell. However when I went to run Sveta it gave this message:
    "Power Pack must be installed to run this program. Visit www.DbPoweramp.com"
    But I just installed it! Anyway I went to the Start Menu and checked the Power Pack Status and it said that it was unregistered (which it is) but that the trial had expired. But like I said I just installed it. I should point out that dbpoweramp itself runs fine. When I go to transfer files to my RIO 600 though it tells me that the power pack needs to be installed!??
    The thing is I have had dbpoweramp for a while and maybe the expiry ran out on that? surely the trial period is on Sveta only though? anyway if anyone could help it'd be much appreciated.
    thanks.
    Yes, there was a bug in Release 5 that started the clock running so to
    speak - run this to reactivate it:
