dbpoweramp conversion error. please, help
  • dmdevotee
    • Aug 2008
    • 22
    I want to convert some ALAC files to AAC, but dbpoweramp gives me this error:
    This is the first time i see this error. Surely the files are not corrupted...
    Re: dbpoweramp conversion error. please, help
    Check dBpoweramp Configuration, does it show .m4a below the DirectShow decoder?
    • dmdevotee
      • Aug 2008
      • 22
      yes, it does...
        • 46228
        If the filter is correctly installed you would also be able to play the file in Windows Media player, can you?
        • dmdevotee
          • Aug 2008
          • 22
          No, windows media player isn't able to play the files...can't find the codec or something. But foobar2000 can
          What i need to install?
          By the way, now when i convert from wav to alac, files are converted but ALL files fail at verification. I'm sure there is something I need to install...but what?
            • 46228
            Try converting the ALAC files to wave, do they convert?
            • dmdevotee
              • Aug 2008
              • 22
              no, they don't convert
              • dmdevotee
                • Aug 2008
                • 22
                This is very strange. dbpoweramp says that the files contains no tag, but foobat2000 reads perfectly the tag.
                I used a new version of tag&rename. Could it corrupt the files?.
                The facts are:
                converting from FLAC or WAV to ALAC (did't manage with new version of tag&rename at all) FAIL at verification
                converting from ALAC to any other codec FAIL at encoding
                ALAC files can play and show tags in foobar2000 but can't play in Windows Media Player and can't show tags in dbpoweramp.
                • dmdevotee
                  • Aug 2008
                  • 22
                  foobar2000 can convert the ALAC files to AAC without any problem.
                  i do not understand why can't with dbpoweramp with all plugins installed
                  • dmdevotee
                    • Aug 2008
                    • 22
                    seems like solved with installing a directshow filter pack called "DC-Bass Source Filter"
                    this is very strange, i never needed to install this to do the ALAC encoding
                    edit: but now, the tracks doesn't encode at their full lenght! this is incredible!
                      • 46228
                      For the direct show configuration .txt file (where you add extensions manually), remove the .m4a because our codec is directly implements .m4a and you should not sepcify .m4a for directshow decoder.
                      • dmdevotee
                        • Aug 2008
                        • 22
                        Thanks! now I can convert without problems
                        I never needed to remove .m4a from that list before, very strange
