Missing Audio After Conversion
  • pearlheartgtr
    • Mar 2009
    Whether it is ripped from a CD or converting an existing file, DB cuts off a few seconds to over a minute of audio at the end of a track. I notice it gets worse if I have multiple files to batch convert.
    I notice this when I convert or when I download something someone else has converted in DB.
    Re: Missing Audio After Conversion
    Converting to which format? also check there are no DSP effects in use.
    • pearlheartgtr
      • Mar 2009
      There are no DSP effects running and I'm trying to convert to mp3.
      Case in point, I just tried converting a 5hr 54min 44sec audio to mp3 and the final product was 5hr 54min 06sec.
        what is showing the length? windows explorer or widows media player do not show correct lengths for vbr mp3 files.
        • pearlheartgtr
          • Mar 2009
          They might be showing the length, but the fact of the matter is that the audio is being cut off when I listen to it. I can play each file and the converted file WILL have audio cut from it.
            Try ripping to wave, is there missing audio? also using which mp3 encoder, lame or fraunhofer?
            • pearlheartgtr
              • Mar 2009
              I'm using the Lame codec. I converted a wav file and it is ok.
                Convert the mp3 file with the problem to wave, does it play ok?
                • pearlheartgtr
                  • Mar 2009
                  Plays ok and is the same length as the cut mp3.
                    On last test, convert the wave file (which was ripped direct to wave and was the correct length), convert it to mp3, what is the length?
                    Which version of dBpoweramp are you using?
                    • pearlheartgtr
                      • Mar 2009
                      I ripped a wav directly from the source and it was short about 30 seconds and converted it to mp3 and that was short 1 second from the wav.
                      I am using version 13.1.
