MPC and DMC Audio CD Input...
  • CastorTroy
    • Sep 2002
    • 26
    MPC is a very fast encoder (~13x on my 1600+), but I prefer doing a slow rip (cd speed : 8x) ; What does the MPC codec doing if he doesn't have enough data to encode at his speed (~13x) ? Will the quality of MPC file contain some mistakes ?
    thanks a lot :-)
    The quality will be exactly the same, in all cases.
    • CastorTroy
      • Sep 2002
      • 26
      So MPC codec set is encoding speed to the cd speed.
      • CastorTroy
        • Sep 2002
        • 26
        "...set HIS encoding..."
          If you want ot look at it like that, then yes.
            Re: MPC and DMC Audio CD Input...
            Dear Spoon
            Please excuse my lack of technical expertise, but I am trying to find a way to use .mpc format files I have downloaded. I have installed the dbpoweramp file converter and the Wavepack codec. Still, my converter cannot read these .mpc files. I hope to convert them to mp3 files so my CD burner can handle them and I can make CDs to listen to at work.
            If you could reply offline, I would be very grateful.
            Peter Gunther
            [email protected]
              You don't need the Wavepack codec, get the musepack (mpc) codec from Codec Central.
