Batch Conversion - Power Pack or Reference
  • rabrown
    • Nov 2008
    • 14
    I would like to register for either the power pack or reference version of the product. Can someone please confirm whether the batch converter functionality is available through the Power Pack or only through the reference version. Thanks.
    Richard
    • 46228
    Re: Batch Conversion - Power Pack or Reference
    If you need dynamic naming then Reference is require, if not the Power Pack (both can have Batch Converter).
    • rabrown
      • Nov 2008
      • 14
      Thanks Spoon. Can you please clarify what dynamic naming allows one to do. For example, when I used the batch conversion with the trial version, it created a folder by artist but not a subfolder by album. I take it that is because I failed to name the new file/folder structure correctly. Would such naming require the dynamic naming functionality.
      Also, when I register (either power pack or reference) do I need to redownload 13.1 or just copy over a registration key. IF I need to redownload do I need to uninstall first?
      Richard
        With the PowerPack and Batch Conversion, if you want to change where the files are located, your only option is to put all the files in one folder with NO subfolders. With Reference, you can use dynamic naming to create a subfolder and filename based on the tags of the file or based from the original file/folder structure.
        • rabrown
          • Nov 2008
          • 14
          Thanks LtData. I purchased the Reference Version. Can I install over the existing trial installation (also v 13.1), and retain existing settings, or do I need to unistall and then reinstall?
          Richard
            You can install over your existing version.
            • rabrown
              • Nov 2008
              • 14
              Thanks LtData. I am now trying to set up the dynamic naming. First I copied the following naming formula from the CD Ripper:
              [IFCOMP][IFVALUE]album artist,[album artist],Various Artists[]\[album]\[track] [artist][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album]\[artist] - [track][] - [title]
              Then I noticed the following that Spoon had previously posted on the forum
              [IFCOMP][IFVALUE]album artist,[album artist],Various Artists[]\[album][IFMULTI] Disc [disc][]\[track] [artist] - [title][][IF!COMP][IFVALUE]album artist,[album artist],[artist][]\[album]\[artist] - [album][IFMULTI] Disc [disc][] - [track] - [title][]
              Can someone explain the differences between the two?
              Also, when batch converting, is there a way to copy over automatically the folder jpg to the new folder structure in addition to the embedded jpg?
              Thanks in advance.
              Richard
                • 46228
                Use the first one of disc number is in the album names, the 2nd one if not.
                  If the album art is embedded in the files, you can use the "ID Tag Processing" DSP effect to export the album art. If it is not embedded, then I don't think there is a way to automatically copy it over.
                  • rabrown
                    • Nov 2008
                    • 14
                    Thanks LtData. I am ripping the cds with CD Ripper into flac format and the album art is being saved in each in flac file and in the folder. Then I am using the batch converter to convert the flac files to lame in a parallel directory/folder structure. Each lame file contains the album art but the folder.jpg is not being saved in the new directory/folder structure where the lame files are being saved. Is there a way to do this with the batch converter and if so how do I do so? Thanks in advance.
                    Richard
                      Yes, when you pick LAME as the codec, use the "ID Tag processing" DSP effect and tell it to export the album art as "folder.jpg".
                      • rabrown
                        • Nov 2008
                        • 14
                        Thanks LtData. If I pick that processing effect will it still add the album art to the file as well?
                        Richard
                          The album art is automatically copied over, you only need to set an option if you want to remove the album art on conversion.
                          • rabrown
                            • Nov 2008
                            • 14
                            Thanks LtData. It is adding the album art to both the file and the folder now.
                            Richard
                            • rabrown
                              • Nov 2008
                              • 14
                              I have done a bit more testing and have the following problem:
                              I have one directory with the following folder:
                              Dvorak; Concerto for cello in Bm; Tchaikovsky; Variations on a Rococo Theme
                              The folder contains the 3 movements of the piece and two other short pieces in 5 separate flac files.
                              Then I used the Batch converter with the following formula
                              and the id tag processing effect to create lame files in a new directory.
                              This created the following folders in my new directory:
                              So instead of ending up with one folder with five files I ended up with five folders each with a separate nameand each with one file. Any thoughts?
                              Richard
