Quality problem when converting .ra to .mp3
  • jpontoli
    • Jan 2008
    I can get PowerAmp to convert a .ra file to .mp3 format, but the result is a file that is just a bunch of garbled/choppy/unintelligible noise. Cannot figure out what I may be doing wrong. Any suggestions?
    Re: Quality problem when converting .ra to .mp3
    Try playing it in Windows Media Player (to test the filter).
    • ghn
      • Jan 2008
      maybe my proposal it not so comfortable, but it will satisfy you with your problem.
      To convert from *.ra to *.mp3 in best quality you should try to do it in two steps:
      1st translate *.ra to *.wav, 2nd *.wav to *.mp3.
      It does not take much time!
      ghn
