Problem Accessing All Music Guide
  • playboysmoov
    • Feb 2007
    • 22
    I have a subscription for all music guide but I cannot access it. I can access the free Internet DB but not AMG. Does anyone know how I can fix this?
    I have it checked off in the Meta section but still nothing. I also went through my firewall (kaspersky internet security 7.0) and made sure that any activity (TCP/UDP) was allowed for this program.
    Any suggestion on how I could fix this problem? Thanks in advance.
    Re: Problem Accessing All Music Guide
    You did the steps here: http://forum.dbpoweramp.com/showpost...83&postcount=5 ?
    • playboysmoov
      • Feb 2007
      • 22
      I don't have a trusted zone in this version, which is 7.0.0.125.
        Is there a Trusted Applications or anything similar sounding?
          • 46228
          Settings >> Firewall >> Configure >> Settings >> Zones >> Add
          • playboysmoov
            • Feb 2007
            • 22
            Ok,It worked. It was under something completely different. It was Settings >> Threats and exclusions >> Trusted Zone >> Trusted Applications. Thanks Spoon & LT Data for being patient and pointing me in the right direction!
            Maybe you can add this a reference in the fixes section for people that use Kaspersky version 7.
              Done.
                • 46228
                I actually have switched to Kaspersky 7 myself so will see if I can fix the data stream they are altering...
