conversion to m4a,aac audio
  • dyl4u2000
    • Dec 2007
    i tried to convert mp3 to m4a using dbpoweramp and nerodigital installed, it allows me to convert audio to he v2 if the settings are on quality .45 and below, if i try to up the settings or choose a bitrate above 80 kbps in bitrate (cbr), the conversion process stops and i get a error that says:
    Error writing audio data to StdIn Pipe [clEncoder::EncodeBlock]
    i normally transfer music to my fone which supports he v1 and v2 and wud prefer he v2 as the file size is small and quality is good and i can fit more songs on my fone.
    Re: conversion to m4a,aac audio
    Neros encoder is not accepting the audio, what is the source attributes? frequency, bit depth, channels?
      If you don't force a profile, does it encode successfully?
      • dyl4u2000
        • Dec 2007
        if the profile is not forced then it converts the audio to regular aac audio not aac+
