why won't dMC Aux. Input capture sound from card?
  • bdinerman
    • Jul 2007
    I have dbpowerAMP installed on my computer. If I play sound files, I can hear them fine through the speakers.
    If I have an external source such as a stereo connected to my sound card, dMC Auxiliary Input is able to capture the sound with no problem.
    Yet the program cannot capture computer-based sound at all. When I play sounds, the recording level always stays at zero within dMC Aux. Input. The program shows the sound card within its settings; I just cannot figure out what I'm doing wrong...
    Thoughts?
    BD
    Re: why won't dMC Aux. Input capture sound from card?
    See here for aux input tips: http://forum.dbpoweramp.com/showthread.php?t=7318
    Also, what OS are you using?
    • bdinerman
      • Jul 2007
      Well, it might sound strange, but I'm running 64-bit Windows Server 2003 at home. My first thought would be that the OS is too high-end for the dbpoweramp software, but I did have the software running at one point. I'm not sure what changed to make it NOT be able to grab the sound going through the card.
      Also, I checked the tips in the link that you provided. All were already in place.
      -Brad
      • bdinerman
        • Jul 2007
        Problem solved. It had to do with selections within the control panel's Recording Control.
        Thanks for the help...
        -BD
          Since the OS architecture is 64-bit, it might not be able to interface with Aux Input, but I am not sure.
