Using CUE to split audio file
    Re: Using CUE to split audio file
    It does not.
    • Lesmo16
      • Jan 2007
      Not currently, it is expected in R13.
      I purchased R16 but couldn't find it.
      I updated to R17 and actually to R17.2 but...
      Where can I find this feature in dBpoweramp?
        dBpoweramp will not split cue files.
        • square
          • Dec 2021
          • 17
          Hi @Spoon,
          just to be clear: Are you saying that dBpoweramp will not split cue files at the current version, or are you saying dBpoweramp will never split cue files because you don't intend to implement this feature?
          Cheers
          square
            The current version does not, perhaps we add in the future.
            • aspiecoder
              • Feb 2023
              Just curious if splitting from a cue file has been implemented in the current version?
                It has not, however we will look at this at sometime.
                • Venoman
                  • Mar 2014
                  • 8
                  #23
                  Still not implemented ? CUE split is a must.
                  • ForSerious
                    • Aug 2017
                    • 120
                    #24
                    Are not cue files self inflicted? To me they have always been the solution to a nonexistent problem: Gapless playback.
                    I suppose it's not uncommon to acquire audio files from less than reputable places… but their use of cue files should be an indicator of incompetence.
                    My point is: If your music is from an online store, you should be able to redownload it in a format that does not have cue files. If it's from a CD, re-rip correctly.
                    Anyway, I can probably make a script that can read cue files and make split-out audio files accordingly, but it's not going to be as amazing as if it were an included DSP.
                      and both cuetools and foobar2000 will split cuefiles into separate lossless files. Point and click.
