AAC --> mp3 problem
  • Ridek
    • Jul 2007
    AAC --> mp3 problem
    Hello.
    I want to convert a audio file aac-format to mp3.
    The aac file is created from a radio stream with streamripper.
    Winamp plays this file correctly with right id tag.
    dbpoweramp R12.2
    Apple lossless Release 6 beta (tried release 5 too)
    m4a Nero (AAC) Release 6
    Windows XP
    Error converting to mp3 (Lame), 'C:\*.aac' to 'C:\*.mp3'
    Error decoding AAC, file is AAC? [clfaad::Create]
    Can someone help me?
    thx Ridek
    Re: AAC --> mp3 problem
    The filename is *.aac, with dbpoweramp you have to pass the individual files.
    • Ridek
      • Jul 2007
      Yes, it is a individual file. I only type in this forum "*" for the folder and the file name.
      • Ridek
        • Jul 2007
        (sorry for double post)
        The AAC-files can be played with Windows Media Player 11 with this codec:
        Orban AAC/AAC+ Plugin
        thx Ridek
          What is the bitrate of the file? Is it a HE-AAC or HE-AACv2 file or just a normal LC AAC file?
          Also, could you go into dBpoweramp Configuration, click the Codecs tab, then click "Copy Versions to Clipboard" and paste that here, please?
            Please send one of the files to:
            • Ridek
              • Jul 2007
              These are the skills of the file.
              aacPlus
              24 kbps
              44100 Hz
              Stereo
              Codecs Installed
              Encoders (write)
              AAC (Advanced Audio Compression)
              .aac
              Apple Lossless Release 6
              .m4a
              .m4a
              mp3 (Lame) Lame 3.97
              .mp3
              Test Conversion
              Wave Release 12.2
              .wav
              Decoders (read)
              Advanced Audio Compression Decoder
              .aac
              CD Decoder Release 12.2
              .cda
              m4a / mp4 Decoder
              .m4a, .m4b, .mp4
              mp3 Decoder Release 12.2
              .m2a, .mp1, .mp2, .mp3, .mpa, .mpeg, .mpg, .mpga, .mpx
              Wave Decoder Release 12.2
              .wav
              Install on Demand
              Monkeys Audio .ape
              FLAC .flac
              Musepack .mpc
              Ogg Vorbis .ogg
              Real Audio (Helix) .ra
              Windows Media Audio 10 .wma
              WavPack .wv
              Midi (read only) .mid
              Shorten (read only) .shn
              http://www.dbpoweramp.com/email.htm
              I sent You a file.
              Hope You can help me.
              Thanks a lot.
              • Ridek
                • Jul 2007
                Are there some news with AAC+?
                  I have the file, thanks for sending, it will be a few weeks before I can look.
                  • Ridek
                    • Jul 2007
                    ok
                    thx
                    • Ridek
                      • Jul 2007
                      What is now with my problem?
                        Our aac decoder is not reading the files, it is based on faad2, we are using the latest version 2.5, so there seems no fix.
                          Have you considered using the nero AAC decoder, Spoon?
                            It is not embeddable, only an .exe
