Trouble with speed control
  • mange
    • May 2007
    • 11
    Why does the cd ripper always start ripping at 4x? If I kickstart the drive with NERO cd/dvd speed then all is ok, cdripper breaks the drive to whatever I want. Speed control works ok until I insert another disc or the drive breaks down due to timeout.
    I believe I have tested all possible speed settings. Yes my drive is dma. I have tried different communication settings.
    SCSI...: Speed control don´t work from within cdripper.
    Windows...: An alert tells me all it can´t do, I don´t want to use.
    Ahead ASPI: same as SCSI
    Sometimes a "ASPI" only, shows and if I pick that one and restart the ripper it can´t find the drive at all.
    Any ideas?
    Re: Trouble with speed control
    If it is an older drive, it might not respond to the MMC3 set drive speed commands.
    You want it to rip at x4 or maximum?
    • mange
      • May 2007
      • 11
      The drive is a Samsung DVD Writemaster. It's about two years old. It shows itself as "TSSTcorp CD/DVDW SH-162C"
      Other programs can control it´s speed. If I just spin up the drive with another program, cdripper seems to handle it somewhat ok.
      Best of course would be if I could set whatever speed I find appropiate.
      Is there something you want me to try?
        There is very little we can do, speed control worked on the 20 or so drives we tested the program with.
